Trimming a door
Discussion in 'Getting Started FAQ' started by Sue28, Oct 4, 2018.
  1. Sue28
    Sue28 New Member
    Hi All, we have two doors that are sticking on our new carpet. A handyman has trimmed the bottom but they are still sticking. He says he can't take any more off the bottom because there are some panel pins in the door and his plane will not cut through them. Is there any way to trim these doors down a further 5-10mm or so do you think, and if so, how would it be done. Thanks
  2. DIYDave.
    DIYDave. Well-Known Member
    A track saw or circular saw would slice through panel pins no problem but agree, if using a plane, these would severely damage the blade
    Mind you, if they’ve been trimmed already and still need another 10-15 mm off, then using a plane is a slow method of attack
    Was it a hand plane or electric plane the guy was using ?
    Are these hollow panel doors by any chance ?
    Sue28 likes this.
  3. KIAB
    KIAB Well-Known Member
    What about using rise n fall hinges might be enough to clear carpet.
    If a cheaper hollow door,there ain't many mm's left for trimming,might end setting in a new piece of timber.
    ramseyman and Sue28 like this.
  4. Sue28
    Sue28 New Member
    Hi, thanks, it was an electric plane, and they are hollow panel doors I think.
  5. KIAB
    Rising Butt Hinges to use the correct name.:oops:
    Sue28 likes this.
  6. DIYDave.
    That’s more the reason as I suspected
    Your handy man guy would have known that the framing on these doors is slim on all 4 edges - around 20/25 mm
    That’s why there’s a small tolerance that the manufacturers recommend can be trimmed - 6 mm perhaps stated on the leaflet tucked in with doors
    But ...... your handy guy can easily cut off 15/20/40 mm, whatever, and simply replace bottom batten
    Couple pins either end then glue and clamp up
    Ok, more work, it’s gonna cost you more but it’s an easy job for anyone that’s slightly competent in diy tasks
    Me thinks he can’t be bovvered with the job in all honestly ;)
  7. KIAB
    Hit the nail on the head...:D
  8. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Or take 5mm off the top, and raise the frame hinges!
  9. Jord86
    Jord86 Well-Known Member
    Tell your handyman to cut the bottoms of the doors with a jacksaw rather than use a plane. He may have to glue and pin a batten back into the hollow bottom of the door to return the strength.
