Hi everyone. I had a triton T70gsi+ 9.5KW and it developed a problem were it seemed to have no inbetween temps it was cold all the way round till the dial got to the hottest setting and be red hot there was no luke warm or anything inbetween. Went and got the exact same shower had it fitted by a professional plumber and now its doing the same?? Can anyone help or advise please
Phone triton for repair.. On old stuff they used to do fixed price repair but your new one will have warranty
I am awaiting a call from there engineer i logged the issue on Thursday with them How could i have a brand new one and same issue though?
Plumber fitted new shower...tested it ran cold and hot and it did so he was happy. I went up for a shower turned dial half way so it's just warm...and it runs cold till dial is turned to fully hot. Same issue as 'old' unit
If old shower worked but stopped and new shower is playing up they must both have a fault. Temperature control is a common fault. Plumber should of fully tested though when fitted.
They've both got same issue. He ran it on cold then turned dial to hot and it ran hot so i cant really blame him. Obviously i want it luke warm as i don't wanna get burnt and then realised the issue
On cold it took 12 seconds to fill a 1 litre jug. Hottest setting took 25 seconds to fill a 1 litre jug
Are they going to do anything about the pressure, what is your main supply pipe made off., and are you on a water meter because im thinking that your main supply pipe has sprung a leak..
