Triton shower
Discussion in 'Screwfix Live' started by Allison Munks, Oct 30, 2021.
  1. Allison Munks
    Allison Munks New Member
    The water is still running out of my shower even after I've turned off the power .
  2. terrymac
    terrymac Screwfix Select
    What model of Triton shower is it ?
    If an instantaneous electric model ,the solenoid is stuck open ,or the on/ off button/ switch is stick closed. Have you switched off the isolation switch ?
  3. Allison Munks
    It's an Triton enrich and yes I've turned off the isolation switch but I've had to isolate the water pipe to stop it running ,do I need to buy a new shower or is there a replacement part I could fit
  4. terrymac
    The solenoid would be a likely candidate for replacement. But a new 8.5 kw Enrich is currently around £ 55 at Screwfix. Fitted one yesterday as a matter of fact.
  5. Allison Munks
    Thankyou for your help that's what I thought
