Truth seeking
Discussion in 'Just Talk' started by longboat, Nov 4, 2018.
  1. longboat
    longboat Screwfix Select
    [​IMG]
    There are 3 boxes, exactly one of which has a car. You can keep the car if you pick the correct box!
    On each box there is a statement, exactly one of which is true.
    Box 1: The car is in this box.
    Box 2: The car is not in this box.
    Box 3: The car is not in box 1.
    Which box has the car?
    btiw2 likes this.
  2. KIAB
    KIAB Super Member
  3. Mike83
    Mike83 Screwfix Select
  4. Sparkielev
    Sparkielev Screwfix Select
  5. longboat
    Someone's won the car.
    But who, and why?
  6. Sparkielev
    If it's a Hillman imp I don't want it
  7. candoabitofmoststuff
    Box 2.
    And I don't want Hillman Imp either... but if it's like my first car, a series 3C Minx... Azure blue with a starting handle, then I'll take it!
    Cando
    Sparkielev and longboat like this.
  8. btiw2
    btiw2 Screwfix Select
    Exactly one statement is true.
    Let’s look at them:
    If the car is in 1. Then 1&2 would be true. So not that.
    If the car is in 3. Then 2&3 would true. So not this either.
    If the car is in 2. Statement 3 is true (and only that one).
    So 2.
    longboat likes this.
  9. Isitreally
    Isitreally Super Member
    3.
    1 is a lie as stated by 3
    2 is true but no car
    3 is true so 1 not having the car only leaves 3
  10. Sparkielev
    that's what I thought
  11. Harry Stottle
    Harry Stottle Screwfix Select
    It's in box 3
  12. Isitreally
    Trouble is btiw2 has put more thought into it and has a plausible answer.
    Sparkielev likes this.
  13. Harry Stottle
    If box 1 is true then 2 is untrue and therefore it must contain a car, but there's only one car therefore 1 is untrue.
    If box 2 is true then 3 must be untrue and box I contains a car, but 1 is untrue, therefore the car is not in 1 or 2 so must be in 3
  14. candoabitofmoststuff
    Now now...
    Instructions say;"On each box there is a statement, exactly one of which is true."
    If It's in box 1, statements on both boxes 1 and 2 are true... so it ain't in box 1
    If it's in box 3, statements on both boxes 2 and 3 are true... so it ain't in box 3
    However, if it's in box 2... statements on both boxes 1 and 2 are false... but statement on box 3 is true.
    So it's in box 2
    Regards,
    Cando
    (I'm pretty sure I've got that all covered!)
    Mike83 and Sparkielev like this.
  15. Mike83
    I went round in circles on that one.
    Cando explained it quite well though.
