Tubular Washer / Spacer - what's it called?
Discussion in 'Engineers' Talk' started by Fingertips, Nov 9, 2017.
  1. Fingertips
    Fingertips New Member
    Hello all,
    I'm not sure if I'm searching for a product that doesn't exist, or I'm stuck because I don't know the correct name.
    I'm basically looking for a tubular washer - a kind of thick tube (or varying length) and various internal diameters that I can use to fit on a bolt and create a "stand-off" from the surface I'm bolting to.
    You tend to get packs of them included with TV VESA mounts, usually made from black nylon, but I'd like to purchase a range of them to use on other projects.
    There are no photos here, but the diagram does at least demonstrate what it is I'm looking for:
    https://www.boltdepot.com/Metric_spacers.aspx
    Thanks in advance!
  2. Jackoftrades
    Jackoftrades Well-Known Member
  3. Fingertips
    Thanks Jackoftrades.
    That isn't quite what I was looking for, but it did give me an idea. I've bought some assorted diameter 1m lengths of thick-walled aluminium tubing. I can cut these to exact length for what I'm looking to do.
    Cheers!
