TV ,SKY, DVD RECORDER, VCR (help )
Discussion in 'Electricians' Talk' started by spindle, Aug 29, 2007.
  1. spindle
    spindle New Member
    Hi all i need some help please
    I have just read some posts on here and managed to set the above set up ( well happy )
    The only problem is when i view Sky through the DVD recorder the picture has a blue tint to it.
    I would really like to get this sorted.
    Thanks for your time
  2. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    You need a switchable scart................probably.
    Watch it, then remove one other scart plug, see if it changes.
    Mr. HandyAndy - really
  3. Ion Transient
    Ion Transient New Member
    uninformed f-up reply..(as usual from this clown)
  4. Mr. Handyandy
    Ooooh, go on then, IntoTrannies, let's have the wisdom of your diagnosis.
    Come on.
  5. jamieblatant
    jamieblatant New Member
    go to services and then setup on sky box set ip menu
    and set picture output output from pal to rgb
    ill post a walk through when i am at my sky box
  6. spindle
    spindle New Member
    Hi
    I have tried that and it is already set on RGB
  7. Max 1
    Max 1 New Member
    If it is not atall clear, you may be using an aerial cable (coax) instead of a scart.
    The modern type of cabling in the digital age is HDMI, which should replace all scart leads.
    I reccomend you follow the instructions offered to you prior of this message, by moderating the setup and services menu settings and if that fails. contact me back. Max :)
  8. spindle
    spindle New Member
    hi
    All ok now i had to change the video setting on the DVD to YPBPR. Thanks for your help
