two wall lights from one switch
Discussion in 'Electricians' Talk' started by woodburner, Mar 16, 2009.
  1. woodburner
    woodburner New Member
    Hello,
    This is for a new room and an electrician will do the job. I just want to know how it is done.
    How are two wall lights wired so they can be operated from one switch. Are junction boxes required?
    Thanks in advance for any help,
    wb
  2. scudo sparky
    scudo sparky New Member
    Don't worry, if your spark is doing it it will be fine.
  3. HoorayHenry
    HoorayHenry New Member
    Yeah right, of course you do!
    Us sparkies aren't as daft as plumbers look you know :)
  4. devil's advocate
    devil's advocate New Member
    2 replies saying effectively the same thing.
    But one does it sooo much more yummily.
  5. Eye Squared R
    Eye Squared R Active Member
    The how is relatively easy, if you know what you're doing?
    The Live (Phase/Line)(Brown or Red wire) takes the 'mains to one side of the switch and when it closes it passes that 'Switched Live' to the light and the lamp lights. If you want the switch to light more than one light then you have to 'distribute' that 'Switched Live' to all the lights you wish to control by that switch.
    You would normally have a cable into the switch supplying the power and then a cable from the switch to the first Light and then a cable from the 1st Light to the 2nd light.
    If in doubt get an electrician or a knowledgeable DIY friend to do it for you.
  6. itwentbang
    itwentbang New Member
    eye squared R
    you forgot to mention the bit about checking for satifactory Zs to ensure disconnection times, checking for minimum IR values in accordance with BS7671:2008
    probably a few other bits aswell. Just to make it easier ;)
  7. yellowfunbus
    yellowfunbus New Member
    ...don't forget it will probably need an rcd/rcbo to conform.
    That is all.
  8. Eye Squared R
    Thanks Guys,
    For the education - I hadn't forgetting about those extras. We might call the need for an RCD 'Additional Protection' - I am only guessing ;)
  9. woodburner
    Thanks Eye,
    No, I don't touch electrics. I am severely colour blind for a start.
    I just need to plan the path of the cables as it is all being run in conduit.
    wb
  10. sysparks
    sysparks New Member
    Just run them up there and down there
  11. Digisatuk
    Digisatuk New Member
    easiest way if ya doin it ya self n no ones gona see it is take the cable thats already feeding the original light at the light fitting end terminal block it n jus run two cables off it one to the first light one to the second bobs ya uncle !!! ( warning im a digital an satellite engineer not an electrician !!! )
