Tyre valves
Discussion in 'Car and Van Talk' started by Notleks, Oct 15, 2020.
  1. Notleks
    Notleks New Member
    Does anyone happen to know the thread size on a car tyre valve and any suggestions for getting to that size male (so I can screw my compressor to it) from a 1/2” bsp female (15mm hose union back plate)?
  2. AnotherTopJob
    AnotherTopJob Screwfix Select
    I'm not sure exactly what you're trying to do, I assume inflate a tyre from a compressor. Normally the compressor pipework would connect to a female outlet, into which you plug your air tools, including a tyre inflator.
    spannerw likes this.
  3. spannerw
    spannerw Screwfix Select
    I can let you know tomorrow morning when I get to work?
  4. Astramax
    Astramax Super Member
    Use Google and search!
  5. Notleks
    Notleks New Member
    Actually I want to drain down a static caravan. Attaching a tyre compressor to the outside tap back plate and blowing all residual water out of the pipe work will leave it safe against freezing through the winter.
  6. AnotherTopJob
    Ok I see. You could buy a tyre valve, cut the rubber end off and push a hose over the stem. You could possibly fit an outside tap to the plate and then connect the hose to that, but normally they have non-return valves.
  7. Notleks
    Notleks New Member
    Thanks for your input. You wouldn’t believe the trouble I’ve had trying to solve this. Normally I’d have gone into the local plumbers merchant and had a rummage round but with covid rules I can’t. I’m sure the valve is either 1/4 bsp or 1/4 npt but which one nobody seems to know. Google included.
  8. AnotherTopJob
  9. teabreak
    teabreak Screwfix Select
  10. Notleks
    Notleks New Member
    Thanks everyone for your input especially “Another Top Job” I don’t know how you found that but it looks like just what I need. Firms can do the job for me and charge about £60. There is also a compressor that another firm install in the ‘van connected to the water pipes to do the same job for £299. So you see why I want to do it myself.
    teabreak likes this.
  11. Bob Rathbone
    Bob Rathbone Screwfix Select
    Use a wet and dry vacuum cleaner and suck it out.
  12. Notleks
    Notleks New Member
    Sorry. Job done. A 1/2” BSP male to 15mm Prestex with a car tyre valve pushed in to stick out of Prestex nut and sealed with Gorrila glue. Screwed into tap backplate and all water blown out with tyre compressor. £1:88 for fitting £2 for valve. Well pleased.
