UFH manifolds: actuators and connections have a standard?
Discussion in 'Plumbers' Talk' started by rk_diy, Jan 14, 2020.
  1. rk_diy
    rk_diy Member
    Are there generic manifolds that we can use with any brand pipe or actuators and not tied up with a brand for spare parts?
    Do actuators have a common fitting standard or all are brand specific?
  2. Dave Marques
    Dave Marques Member
    It's best to stick to the same brand as the manifold. They have different threads and 'stroke' lengths so while some will work on a different manifold, others won't.
  3. The Teach
    The Teach Screwfix Select
    What does your intended highly experienced installer recommend,its not diy :)
  4. rk_diy
    rk_diy Member
  5. The Teach
    Decent manifold products from well known heating manufactures like Danfoss will last a long time,as long as they are installed correctly.
    Danfoss will be around for many years,cant say that about some of the unknown,rebadged or unbranded products. Spares can be intermixed,many people just purchase the cheapest items and hope for the best ;)
  6. rk_diy
    rk_diy Member
    thats very true but "local availability" from retailers is important as well. I had a quick look and couldn't see a price or even a complete set of Danfoss manifolds. It seems their marketing focused more on controllers here. I was considering Hep2o's manifold but not sure about their composite manifolds rather than brass. Better to go for a well known, well-tested and tried for long time system. Lets see what other recommendations will come up :)
  7. rogerk101
    rogerk101 Screwfix Select
    I have bought several UFH systems from different vendors, including our hosts, and many of them mix and match individual items from different vendors to pull them together into tried and tested systems. The vendors themselves take on the role of system integrator and will help you with any incompatibility issues you may have. I found these guys to be really great (https://www.underfloorheatingsupply.co.uk/underfloor-heating-kits).
  8. Dave Marques
    Dave Marques Member
    The down side of that is when a problem develops, the manifold manufacturer blames the supplier of the actuators and vice versa, leaving the installer high & dry. I understand people looking to save money but for me, I'd rather fit a Grohe tap or Uponor actuator, pay the premium and have piece of mind.
