Evening all. We have recently moved house and are looking to carry out an extension. The property has a gravity fed hot water system with a new boiler (2019) My question is can I run underfloor heating on a traditional gravity fed system? If not why not? Thanks in advance W
hi ufh on ground floor will work fine just need a zone valve off the main boiler primarys. to connect to the punp set and mixer. if upstairs, you may have problem with getting air out. good luck peter
