Underground Connections
Discussion in 'Electricians' Talk' started by MICC, Nov 17, 2003.
  1. MICC
    MICC Member
    Has any one in the trade any suggestions on underground connections, ie besa boxes with micc or swa cables.
    Have being using melted wax to seal the joint, which works quite well, I know this is an old way of doing things but there does not appear to be much on the market now.
    The wax is fine until you need to open it up to fault find, any thoughts?
  2. gerrin2owd
    gerrin2owd New Member
  3. gerrin2owd
  4. MICC
    MICC Member
    Thanks el for that, will look in to it...
