Understairs cupboard construction?
Discussion in 'Carpenters' Talk' started by FUNDIMOLD, Feb 15, 2020 at 10:33 AM.
  1. FUNDIMOLD
    FUNDIMOLD New Member
    Hello
    I want to use the space under the staircase as a store cupboard (image_1) I've been quoted £600 to create the frame and doors which sounds toppy to me so I'll have a crack at it!! There is no finishing required in the space behind the doors as it should be clean enough for the hoover and dog food that'll be stored inside. My concern is the existing panel seems flimsy (plasterboard or hardboard?) and will need to support a frame to mount the doors (mdf?). Can anyone direct me to online instructions or suggest the best materials to use. I have attached photos of a neighbour's version which is exactly what I'm after but he got a chippy (no longer available) to do his. Any pointers appreciated. Cheers
  2. Jord86
    Jord86 Well-Known Member
    2x2 or CLS for the framework, a regular softwood door lining kit, large flush hinges, and 22mm MDF would be the materials of choice. With a bit of architrave to match the rest of the house.
  3. FUNDIMOLD
    Thank you Jord. Here goes....!
