uneven gloss layers
Discussion in 'Painters' Talk' started by Ash01, Nov 3, 2019.
  1. Ash01
    Ash01 New Member
    Hi ,
    I’ve stripped the handrail, however it’s also lifted some gloss from the spindles. There are layers and layers of gloss, so now there is a lip between the stripped gloss (it’s gone back to wood) and the existing layers of gloss. I don’t want to strip the spindles however would like a flush finish to regloss.
    - Do I sand the lip and try to get it feathered the best I can ?
    - is there some filler that I need to use to re level it ?
    Thanks you . PS I’m new to DIY sorry I appear to ask daft questions :)
  2. Wayners
    Wayners Screwfix Select
    Think you need to get the lot off. Just my opinion or its not going to look good filing in.
  3. Astramax
    Astramax Super Member
    Can you post a photo? maybe best to sand the damaged areas and fill with 2 part filler such as Ronseal wood filler.
