Universeal Grout Rescue Colour & Seal
Discussion in 'Tilers' Talk' started by Iron_Mike, Oct 4, 2018.
  1. Iron_Mike
    Iron_Mike Active Member
    Hi
    Has anyone used this before ?
    If so, how did you find the product?
    I grouted a kitchen in gunmetal, but with the works that have gone on it has been difficult to maintain this colour.
    I am reluctant to regrout, so if this product is good, I could darken the grout without the hassle of digging it all out and regrouting.
    Any advice appreciated.
    Cheers
    IM
  2. KIAB
    KIAB Well-Known Member
    Some praise it, others don't rate,need to be throughly shaken before use.
    Iron_Mike likes this.
  3. Iron_Mike
    Cheers KIAB
  4. rogerk101
    rogerk101 Well-Known Member
    It depends on whether grout sealer was used in the original grout or not. If it was, then this product is likely to come out very blotchy. Also if there was a lot of cooking fat/grease that found its way into the original grout, then this product won't soak in in those areas.
  5. PhilSo
    PhilSo Active Member
    I saw the same instructions on this box!
    PhilSo :cool:
    CGN likes this.
  6. Iron_Mike
    https://www.toppstiles.co.uk/tprod4...=4f1ea7ff418855845a72230da0edb908&fo_s=gplauk
    This was the grout I used.
    I applied it and did not do anything else apart from this.
