Unkinking Appliance Flex
Discussion in 'Electricians' Talk' started by MadDesigner, Feb 10, 2004.
  1. MadDesigner
    MadDesigner Member
    When one buys a new appliance the flex is usually bundled up tightly and secured with a wire tie. This results in a zig-zagged flex that is impossible to conceal neatly without it popping into sight unless it is secured.
    Does any one have a good method of doing this (apart from leaving it for 3years to relax naturally!)?
  2. GrahamB
    GrahamB New Member
    Stick it in a <u>warm</u> oven for a few minutes and then straighten it out by stroking with a cloth. Let us know how it works - I havn't tried it!
  3. MadDesigner
    MadDesigner Member
    Hmmmmmm.......Don't think my new mains powered CO monitor would like that nor would our 28" telly fit in the oven ;)
    Would soaking the flex in some boiling water do the trick? A bit loath to try this though I s'pose it should be OK, wouldn't it?
  4. lastword
    lastword New Member
    Hairdrier
  5. ban-all-sheds
    ban-all-sheds New Member
    Get out more.
  6. unphased
    unphased Screwfix Select
    A good method of straightening cables and flex is to draw it through a tightly held rag or cloth, such as towelling or similar, several times. Try it, you will be amazed at how good this is...:)
  7. Dewy
    Dewy New Member
    I've put it under tension (got 2 people to hold it straight) while passing a hairdryer along the length. The kinks soon come out. Just keep the hairdryer moving so you don't heat up one spot more than the rest.
  8. sparky Si-Fi
    sparky Si-Fi Screwfix Select
    bring back rubber flexes I say,cant beat 'em during a cold snap,best thing for extension leads!
  9. sparky Si-Fi
    actually to add to this as well,all my De-walt and Makita power tools have rubber flexes,would hate to have PVC on them on a cold frosty site morning!
  10. Dewy
    Dewy New Member
    I have a length of very thick rubber covered lead plugged into an RCD socket in the kitchen. It goes through the top of the door frame & was fed through a length of hosepipe & clipped to a tensioned wire to the garage. It feeds a number of socket outlets in there including a light.
    I only use one tool at a time plus the light.
    I shouldn't have said this in the sparkies forum. Some might have a fit. ;)
  11. The Trician
    The Trician New Member
    Very thick rubber eh? Naughty naughty!
    Not kinky either I'll bet :)
  12. Dewy
    Dewy New Member
    No kinks at all (lol) apart from where I made a kink to prevent rain running in.
  13. GrahamB
    GrahamB New Member
    If the lead is attached to the appliance - as against a plug and socket lead - the hairdrier approach and 'stroking' with a cloth sounds good.
  14. magsevern
    magsevern New Member
    GrahamB IT SOUNDS BLOODY GREAT
  15. The Trician
    Yeah! Especially the 'stroking' bit :)
