Mandolin Joe
Member
Hi, We
We have recently knocked down a wall between our dining room and kitchen.
Both floors don't seem to be flush with each other.
The wall was a little over 2m wide.
On the floor, where the wall used to be is a ramp rather than a flat surface.
The ramp is obviously the same size of the wall thickness (approx 150mm).
The problem is that the ramp is not uniform along the length of the ramp.
What I'm saying is at one ned of the ramp, dimension A is 30mm, while at the other end, dimension A is 3 mm.
We would like to lay some laminate flooring over both rooms so I'm not sure how to tackle the issue.
