Unplugging equipment.
Discussion in 'Electricians' Talk' started by The Dormouse, May 23, 2008.
  1. The Dormouse
    The Dormouse New Member
    A local elderly lady died when she was overcome by fumes when her TV caught fire while it was left overnight on standby. The coroner recommended that people should pull out their mains plugs.
    I wonder if others agree that this is very bad advice, because although it‘s acceptable to turn equipment off at a wall switch, pulling out a 13amp plug every time equipment is not needed is asking for trouble & could even be counter-productive.
    Regular use could loosen connections in plugs & sockets, & the inevitable slow make/break action will cause arcing. This is made worse in the case of sockets installed low on a wall that are difficult to reach without wobbling the plug while it’s being removed or inserted..
    My elderly sister was persuaded to pull out her mains plugs at night, so her cordless phones stopped charging. They gradually went dead as she forgot to reconnect them in the mornings, making them useless as a nearby means of calling assistance in an emergency.
  2. Clark Kent
    Clark Kent New Member
    Quite often plugs/sockets are not readily accessible are they?
    But TV's still have a on/off button don't they?
  3. Well if they do my children don't know how to use it!!!
  4. Clark Kent
    it!!!
    Hardly surprising, is it..
  5. prosparks
    prosparks New Member
    Double pole sockets are good as it allows just the switch to isolate both poles.
    Still awkward to get to maybe.
    I never unplug anything, I must admit.
    In the even of local storm , its possible to get damaged gear tho
  6. sysparks
    sysparks New Member
    I would like to rewire my home and move mains to more accesible location.
    Then every night i would turn off the down skts and kitch skts mcb`s.
    But maybe im just tight!
  7. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    are they?
    Nah. A lot of 'em nowadays have one button. It's either ON or on STAND-BY. :(
    Mr. Handyandy - really
  8. fcu for the telly etc.
  9. Clark Kent
    Or a remote..
  10. Coloumb
    Coloumb Screwfix Select
    I forgot to unplug my ace the other morning.
    Of course it went up in fumes.
    I still can't be aced to unplug it.
    Maybe that's why I'm so full of *...
    [Edited by: admin4]
  11. BIG LEROY
    BIG LEROY New Member
    [Edited by: admin4]
    Have you remembered to unplug your anal butt plug?
  12. Coloumb
    I can't believe admin4 made an edit to *
    I'm well scratching my head now...
    [Edited by: admin8]
  13. Coloumb
    I bet anal butt plug is left "as is".
  14. BIG LEROY
    I see why you're in a good mood then :)
  15. MR DIAZ
    MR DIAZ Active Member
    You shouldn´t leave TV´s on standby
    Let alone over night.....
    As sad as it is, it´s her own fault
  16. The Dormouse
    Maybe, but that's not really the point is it?. There should be a convenient way for the public to turn off equipment at night without having to go round pulling out plugs. We have health & safety legislation to deal with loads of other less important matters.
  17. MR DIAZ
    out plugs.
    On my TV´s there´s a big switch on the front of it for this means
  18. Mr. Handyandy
    Don't sockets have switches on them any more then ?
  19. MR DIAZ
    Good evening Andy
  20. JP.
    JP. Screwfix Select
    Sommething more to that TV stanby thing then meets the eye..
    1..On standby surely it is only the remote control switching circuit which is active active (IR switching)..a few mA at the most an all well protected.
    2..There are so many things which are on all the time..ie fax machines..cordless phones..this that and all protected by thermal fusing and variations of..
    Is is something to worry about on a general level?
    I don't think so.
