Updating Danfoss RMT230
Discussion in 'Electricians' Talk' started by KenAb, Oct 7, 2019.
  1. KenAb
    KenAb New Member
    I want to replace this with a Danfoss or Honeywell programmer. I searched earlier requests for help but my concern is the only wires going to above is a Live, Neutral and earth which appears to loop to the back. The other threads have said they have another wire (switching) but not this one. The boiler is a Vaillant Combi. As I would have to fit the programmer unit and back plate please advise the correct wiring connections , is it as straightforward as to N and L or different markings on the new backplate.
    Thanks
  2. Mike83
    Mike83 Screwfix Select
    Ot should have neutral but it can work without one.
    In this case yours has a live and switched live.
  3. Mike83
    Is it a programmable stat your looking to buy.
    If so one that’s powered by batteries would be the easiest solution.
  4. KenAb
    KenAb New Member
    I’m open to suggestions about best one to buy for simplicity, definitely a programmable one, budget around £60 to £80. the red and black wires on the Danfoss RMT230 if neither are neutral assuming I go for your suggested programmers what connections would my red and black go to.
  5. Mike83
    Depends what you buy.
    Connections vary depending on manufacturers.
    Could be numbered or called common and NO.
  6. Mike83
    If you buy a stat that’s powered by batteries then the two wires can go into either connection on the new stat.
  7. Mike83
  8. Mike83
  9. Mike83
    One wire into 2 and the other into 3
  10. Mike83
    Any battery powered stat will work with 2 wires.
  11. KenAb
    KenAb New Member
    Thank you so much will order it today.
  12. Mike83
    It doesn’t have to be this specific one.
    I chose this to show how easy it would be to wire.
    There’s other stats that are more user friendly than this. Have a look.
  13. KenAb
    KenAb New Member
    Just to say all connected and working, thanks so much for your help
