UPVC Door Cap? What do I need?
Discussion in 'Getting Started FAQ' started by Andy Markwell, Aug 11, 2018.
  1. Andy Markwell
    Andy Markwell New Member
    My conservatory door appears to be missing a cap/end. It basically means there’s a big gap and in winter the conversatory is freezing.
    I’ve looked around and can’t figure what i need to buy to replace.
    Any help would be appreciated
    Thanks
  2. Isitreally
    Isitreally Well-Known Member
    Fill it with silicone, easy enough to do.
  3. DIYDave.
    DIYDave. Well-Known Member
    Do you know the profile / manufacturer / or supplier of units ?
    If so, spares should be available, trouble is there’s no generic cap that fits all so you need to ID doors and then contact supplier
  4. Andy Markwell
    Thanks for that,
    Is there an easy way to find out the profile etc?
  5. ginger tuffs
    ginger tuffs Member
    make one yourself out of a plastic lid and glue on
    DIY womble likes this.
  6. Jord86
    Jord86 Well-Known Member
    Expanding foam.
  7. DIYDave.
    :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
    But ‘if’......
    You know the make of the units, it’s even easier to just call the manufacturers and they will pop em in the post for you, or locate a local suppliers
    Have a look for any ID on window openings / frames, sometimes yes / no
    My units are Rehau. Called them up few years ago as same piece as urs was missing and a few end caps from window sills. All sent out free of charge - great customer service
    Of course, if you can’t ID, then you may well have to go down the route of a mentioned bodge job :D
