UPVC DOOR lock barrel
Discussion in 'Builders' Talk' started by RATP, Sep 25, 2021.
  1. RATP
    RATP New Member
    Hi. I need to replace a lock barrel. Where I’d normally expect to see the retaining screw is just a small hole. If I remove the top to bottom plate (around 20 screws) the multi point lock latches would also be released. Any ideas?
  2. Starslikedust
    Starslikedust Active Member
    Can you upload a photo?
  3. koolpc
    koolpc Screwfix Select
    Is the hole threaded? If so, the small screw has been removed already. In that case, the barrel should slide out with a turn of the key! Yikes!!
  4. RATP
    RATP New Member
    Sadly not!
  5. sparky steve
    sparky steve Screwfix Select
    The threaded part for the securing screw is in the euro cylinder body.
    Remove the retaining screw.
    (You state the retaining screw is not present?)
    Loosen the screws on the lock’s faceplate. Insert the working key into the lock.
    Turn the key to either side and gently pull the lock toward you.
    Continue turning the key until the lock slides free from the door.
    Baxi Boy likes this.
  6. RATP
    RATP New Member
    Thanks. I’ve tried that but there is no face plate.
  7. RATP
    RATP New Member
  8. sparky steve
    A7B18887-2151-4634-B25D-DF960CA0BA79.jpeg Have you tried removing this screw?
