UPVC Door Not Closing Fully
Discussion in 'Builders' Talk' started by Jay777, Nov 25, 2021 at 11:32 AM.
  1. Jay777
    Jay777 New Member
    Hi,
    I am having issue with the UPVC door not fully closed upon closing the door.
    What I mean is that when closing the door, I could touch the door by my finger tip and it opens meaning that it is not fully closed in position when closed.
    I have to lift the handle up to get the door fully closed when in place..
    Is this a common issue? Do I need to adjust the hinges?
  2. WillyEckerslike
    Possibly the latch/keep first rather than the hinges if I've understood you correctly.
    Edit: Lifting the handle engages the espagnolette which pulls the door in against the frame and locks the shoot bolts
  3. Jay777
    Jay777 New Member
    Thanks, will try this and let you know how it goes :)
  4. Wayners
    Wayners Screwfix Select
    Yeah.. Latch on frame needs adjusting. Probably come lose and needs putting in correct place and tighten up. Screws are an odd size if one or both missing
    Jay777 likes this.
  5. Jay777
    Jay777 New Member
    Cheers :)
    Will let you know how it goes..
  6. Jay777
    Jay777 New Member
    If the door is a bit draughty, then I assume would need to adjust on the door not the frame? Just like in the YouTube video below?
  7. Jay777
    Jay777 New Member
    Adjusted the latch keep and hinges. Door now latching fully.
    Cheers guys.
    WillyEckerslike and Wayners like this.
