Upvc hinge adjustment?
Discussion in 'Other Trades Talk' started by Salpaul, Jul 26, 2021.
  1. Salpaul
    Salpaul New Member
    Hello group :)
    My first post, any help much appreciated.
    Had a look at my sons upvc door as it needs adjusting, although I've adjusted quite a few upvc doors in my time I was not sure about this type, I assume the adjustment screws etc are behind the big flap shown in photo but I didn't want to force it in case I damaged it.
    Best regards
  2. GS63
    GS63 Member
    Salpaul likes this.
  3. jonathanc
    jonathanc Screwfix Select
    Open the door and show us a picture from the other side of the hinge I bet there is an adjustment there
    Salpaul likes this.
  4. Salpaul
    Salpaul New Member
    Thanks for your reply :)
    I did try to prise that flap open but not much force as I was afraid of damaging anything
  5. Salpaul
    Salpaul New Member
    See below.
  6. jonathanc
    As I guessed the adjustment is the nut on the middle “bar” in that hinge. You can see the thread on it
    Salpaul likes this.
  7. Salpaul
    Salpaul New Member
    Thanks Jonathanc
    Am I correct that nut will adjust width?
    If so how do you adjust height?
  8. jonathanc
    width yes. height you don't adjust. if the frame were fitted plumb then no adjustment should be needed
    whats the issue causing the need for adjustment?
  9. Salpaul
    Salpaul New Member
    The door is a tight fit and requires some effort to close, which does suggest that nut will solve that issue, the other issue when the door is closed the lock (applied on inside by thumb knob rather than key and key on outside) is hard to turn but I need to have another look at that next time I visit
    Cheers
    Paul
  10. jonathanc
    those adjusters are out quite a lot. wind them all back in a bit and i bet that solves the problem
    Salpaul likes this.
  11. Salpaul
    Salpaul New Member
    Thanks mate :)
    Will do that next time I visit, or pass the message to my son and he can have a go.
  12. Kas228
    Kas228 Screwfix Select
    Is it all 3 or just the central one the adjuster. As I have a similar issue
  13. TMB1984
    TMB1984 New Member
    I'm absolutely no expert but bear in mind I think some times the doors do expand in sunlight when really hot (as it has been recently). We've found that we can't close ours after a seriously hot day (South facing) until later in the evening.
  14. Salpaul
    Salpaul New Member
    I think it will depend on where it's tight, if it's say tight only at top adjust top bolt etc
  15. Kas228
    Just adjusted mine, it was slightly different as there was a Allen key type adjuster under that white plastic cover (other side from photo position). Moved top and middle in slightly and it’s opening/closing a lot easier.
    Salpaul likes this.
