Upvc patio door Replace Seal advice
Discussion in 'Builders' Talk' started by Daveab, Nov 24, 2021 at 9:13 PM.
  1. Daveab
    Daveab New Member
    Hi past few years I've noticed our patio doors seem to let a draft in I've tightened up the keeps messed with the hinges outside etc and they have improved but you can still feel the cold in the bottom corner.
    Noticed the rubber gaskets on the doors look a bit worn although the house is 9 years old should they need replacing yet?
    I've ordered this online but noticed my gaskets are a different shape :unsure: that'll teach me for not checking :cry:.
    https://smile.amazon.co.uk/dp/B07W998GD1/ref=cm_sw_r_apan_glt_fabc_ZXBQN0JCVBBSXPXKVBWE?_encoding=UTF8&psc=1
    The one that's around the doors currently is this type
    Would it be ok to switch them or will that make it worse?
    Not sure if the current seal is this type?
  2. Wayners
    Wayners Screwfix Select
    I bought a sample pack of 10 off ebay and found the best match. None were identical but one fitted OK
    Daveab and WillyEckerslike like this.
  3. ChrisM123
    ChrisM123 Member
  4. Daveab
    Daveab New Member
  5. Daveab
    Daveab New Member
    Well got my sample pack and i'm still not sure, there all alot thinner than what's currently in the door
  6. Wayners
    Thinner but do they work?
