The Legrand complies with the requirements for telephone equipment interoperability and is Class II double insulated, it’s not Class III SELV and unsuitable for use in a bath or shower room within 2.5 metres of zone 1. Conform to IEC 62684-2011-0 Class II SELV The particular one you have linked to also lacks the voltage and current labelling on the front of it. These are battery chargers for IT equipment, not power supplies for appliances and lighting, the manufacturers state that.
Is this actually as simple as: USB sockets and cables are grounded, therefore they cannot be SELV and are actually FELV? https://www.tlc-direct.co.uk/Book/7.16.3.htm
I do not understand your point. The bathroom cabinet that the OP proposes is not earthed in any way. The provided cable has no earth and the USB charge socket, if it as it is SELV, will not provide an earth either.
Do you believe in fairies and unicorns? Here’s a typical modular USB charger showing its markings, which ones show it is SELV? https://www.bgelectrical.uk/public/downloads/data-sheets/euro-module/euro-module-usb-data-sheet.pdf Can you find one with the SELV sign on it? https://flairlight.co.uk/wp-content/uploads/Symbols-Explained.pdf
Thank you. That was one of the two USB sockets that I had already identified and provided links for (some days ago). As far as I am concerned that should do the job. I do not disagree (again I have already said) many USB chargers are not compliant and the OP must identify one that is. From the definitions, A Class III product is designed to be supplied from a separated/safety extra-low voltage (SELV) power source So that will be the mirror. The mirror will be powered from the SELV USB socket. Sorted
The one that says on the same data sheet they are only suitable for use in dry interior locations? The installation instructions are even more explicit, stating that they MUST NOT be installed in bathrooms, the manufacturers use of capital letters not mine, they also don’t have a suitable IP rating. https://manualzz.com/doc/27613652/mk-k5837-power-module-installation-manual Honestly, you have a better chance of finding a fairy riding on a unicorn than finding a USB charging device suitable for use within 2.5 metres of zone 1 in a bathroom or shower room.
Yes. That’s fine. Behind/above the cabinet will be nice and dry, wouldn’t you think? Or install it in the loft above the cabinet??
The Legrand item linked to is marketed as Class II sELV. Check the description here. https://www.xppower.com/resources/blog/iec-protection-classes-for-power-supplies
SELV is Class III, not Class II. BS7671 clearly defines the requirements for SELV power sources and these USB chargers don’t meet the requirements.
From the Legrand catalogue: From the MK datasheet: Both manufacturures, with their huge resources, state SELV. If you disagree then maybe you need to take it up with the manufacturers and Trading Standards.
I used the USB cable, cut the USB plug off and wired directly into a 240v ac to 12v dc led lighting transformer via a 12v dc to 6v dc step down module I found from Amazon. Both went into the void in the plasterboard behind the mirror. Nice and easy and worked perfectly.
IEC 62684:2011 specifies the interoperability of common external power supplies for use with data enabled mobile telephones. It defines the common charging capability and specifies interface requirements for the the external power supply. Safety and EMC aspects are not covered by this International Standard. Safety is covered by IEC 60950-1 and EMC is covered by EN 301 489-34. The French version of this standard has not been voted upon. https://webstore.iec.ch/publication/7365 The bit you need to read is : “Safety and EMC aspects are not covered by this International Standard.” This device has absolutely no safety approvals for being used in a bathroom.
No, wrong again. I don't need to read anything. The manufacturers both state SELV. If you think you know better than them with their resources and certification then a) what a huge ego you have b) take it up with them, I didn't fill in the documents.
The USB chargers you are linking to do not not comply with BS7671:2018:A2:2022 Regulation 414.3 Sources for SELV and PELV. So only have very limited uses, I'm not saying you can't use them for their intended purpose, charging mobile IT equipment, but they are not SELV devices for use in bathrooms and shower rooms within 2.5 metres of zone 1. This has run its course.
