Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I first saw these 8 years ago in a new hospital in Malta, these must have been accepted by the architects, or even specified, so I see no reason why they should be considered unsuitable. Malta is in the EU, just as Spain is, so common rules and acceptances apply. The USA is slowly adopting our 13A sockets in some installations, the domestic users are frustrated at the low power 1.5 kW available at their 115 volt 10A outlets.UK expats invariably come a cropper using UK fittings abroad, whether it be plumbing in France or electrics in Bulgaria or elsewhere. In the Bulgaria case he was told to remove everything and start again to Bulgarian standards. In the French plumbing case he found he could not sell when the time came.
So my advice is don't do it. I'm sure Spanish fittings are available.
As far as 13a sockets are concerned I know they are not allowed in Spain the same as Schuko are not allowed in the UK. As for a socket that accepts a 13a plug as well a a 2 pin one, I have seen those in the far east and they are dangerously made and do not comply to any countries standards. Also if you (can) insert a Schuko plug into one of these the earth (2 side strips) will not connect.
The UK fittings will carry the CE mark so they will be accepted in any EU state and the UK.
I appreciate your reply. However, I don't want to fit UK sockets. I was asking only about light fittings, specifically fitting UK pendants, but with an E27 bulb holder rather than a UK-style bayonet. The three-terminal ceiling rose has a live, neutral and earth. Common sense says that should be compatible and not pose any risks. But I'm not an electrician, and perhaps I'm missing something. The only reason I'm considering buying UK fittings is because it's easier for me to source them here in the UK and take them with me than to find the same thing in Spain.UK expats invariably come a cropper using UK fittings abroad, whether it be plumbing in France or electrics in Bulgaria or elsewhere. In the Bulgaria case he was told to remove everything and start again to Bulgarian standards. In the French plumbing case he found he could not sell when the time came.
