Vaillant Boiler Pressure Loss
Discussion in 'Plumbers' Talk' started by stonemason, Feb 14, 2020.
  1. stonemason
    stonemason New Member
    My daughter has a 1 bedroom flat in London which she lets through an agent. The agent is constantly having to call out a engineer to repair boiler due to pressure loss. The boiler is only 10 years old, but she is considering replacing the boiler due to high cost of repairs!
    I'm not convinced this is the answer, but would appreciate your thoughts on this problem
  2. Mike83
    Mike83 Well-Known Member
    A couple of visits should identify if the leak is due to the boiler or the system.
    On the boiler the heat exchanger, vessel and prv need checked.
    All pipework and valves also need checked. There could be a leak under the floor but process of elimination should point to the cause.
    How often does the pressure drop?
    masterdiy likes this.
  3. stonemason
    Hi Mike,
    Not sure if I'm honest, as its a let property, but my daughter thinks buying a new boiler as a cheaper option than keep repairing the exiting one.
  4. masterdiy
    masterdiy Well-Known Member
    If you do go for a new boiler, stick with Vaillant. It will be a straight swop, & an easy job.
    Providing of course it is the boiler.
  5. Mike83
    Imagine changing the boiler and the pressure loss persists.
    The boiler/system needs checked over by someone who’s competent.
    Muzungu likes this.
  6. Bob Rathbone
    Switch off the boiler and close the outlet valves on the boiler and see if the pressure still drops, if it does, the leak is in the boiler.
  7. The Teach
    The Teach Well-Known Member
    Their repair people will just get it up and working,you really need a heating technician to investigate why the system is dropping pressure before deciding on a new boiler.
    Heck,thats past it's best for a rental property.
