Veritas R8 OLD Installation Manual
Discussion in 'Electricians' Talk' started by Parsy, Feb 26, 2008.
  1. Rulland
    Rulland Screwfix Select
    Between gripper and skirting is not fine imho, over time the cable sheathing and core covering gets worn through, you start to get intermittent faults which are a real pain to find, seen, and had to deal with it numerous times :rolleyes:
    Or damaged when carpets replaced.
    KIAB likes this.
  2. Mike58
    Mike58 Screwfix Select
    We could discuss this at length ... but what causes the wear ? Hidden from view, no one can tread on it - maybe not perfect but better than running under a carpet.
  3. sparky steve
    sparky steve Screwfix Select
    Between gripper & skirting is still not ideal, the carpet is stretched over the gripper & then edge of carpet is usually pushed down with a bolster by the carpet fitter. I’m sure the carpet fitter will take extra care whilst performing this task:rolleyes: and the carpet edge will not sit in the gap due to it been occupied by the alarm cable. If there is no better routes for the cables i would consider the wireless option. Upgrade now & save all the hassle you will no doubt encounter in the not so distant future (sods law :( )
    Good luck
  4. Darl Lyn
    Darl Lyn New Member
    Maybe better to supaglue cable to gripper rods on underlay side ....sounds a better idea...also less chance of chiesel they use to tamper carpet over the gripper damaging the cable too.
    Thanks
  5. Jimmystoba
    Jimmystoba New Member
    @Rulland any chance of a copy of the pre 2000 Texecom R8 destructions please? Just fitted the old panel out of my house in the garage then started to struggle when programming it. It's the one that gets into programming by 'engineer code/00' sj236508@gmail.com Thanks in advance. Jimmy.
  6. Rulland
    Email sent Jimmy.
    Jimmystoba likes this.
  7. Jimmystoba
    Thanks for the fast response @Rulland you're a superstar! :)
  8. John Sadowski
    John Sadowski New Member
    Hi rulland
    Any chance you can send me a copy of the old veritas install manual aswell please. Got one that need some changes made but can't remember the old Programing code
    John@astra-alarms.com
    Thanks
  9. MickDickinson
    MickDickinson New Member
    Hi Rulland
    Any chance you could send me a copy of the Veritas old installation manual please, it lgot a problem with the alarm falsely activating and want to test the circuits
    mickdickinson@btinternet.com
    thanks in advance
    mick
  10. Rulland
    Email sent Mick.
    MickDickinson likes this.
  11. MickDickinson
    Thanks a lot, we’ll received
    Rulland likes this.
  12. Clive Baldy
    Clive Baldy New Member
    Mine is a 1996 R8 which responds to 00 instead of prog. I've carried out some changes from the later manual but if there is any chance you can send me a copy of the original I would appreciate it. Thank you. clivebaldy1@gmail.com
  13. Rulland
    Manuals despatched.
  14. Nikos Finidis
    Nikos Finidis New Member
    Rulland can you sent me a copy pls??
    Mine does not change the user code with 60.
    Thank you so much.
  15. Rulland
    I'll need an email address mate, preferably a disposable one, as you don't want all and sundry knowing a proper one, unfortunately private messaging has been disabled by Screwfix because the few ruined it for the many.
    Nikos Finidis likes this.
  16. Nikos Finidis
    Sry... nik.finidis@gmail.com
  17. Razzle dazzle
    Razzle dazzle New Member
    Hi mate may I have a copy to please here is my email melongjon@msn.com
  18. Rulland
    Email sent.
  19. Razzle dazzle
    Thanks mate life saver
  20. Benw1234
    Benw1234 New Member
