Villavent airflow
Discussion in 'Other Trades Talk' started by Mike2021, Sep 8, 2021.
  1. Mike2021
    Mike2021 New Member
    Hi
    I've just moved into a flat with a villavent vvx200/2 and I'm trying to figure out of its working correctly. When powered on, I can hear it going and there's weak airflow into and out of the vents. In the bathroom, when it is set to max, the air is being sucked in at a very low rate, barely enough to grab hold of a square of toilet tissue. I've taken the case off and the aluminium filter doesn't look dirty and the other filter doesn't look dirty. It is opaque though and im not entirely sure what a clean one is supposed to look like.
    What level of suckage should I expect to be getting when on max ? Or even on low which is what I think it should be set to as standard?
    Thanks
