Vinyl Adhesive.
Discussion in 'Other Trades Talk' started by glob@l, Jan 17, 2019.
  1. glob@l
    glob@l Member
    Does the adhesive fitters use to (fully) stick vinyl leave a mess when it's eventually lifted?
  2. Wayners
    Wayners Well-Known Member
    Not if you try not to smear all over them place and wash of with warm water and dry with white paper towel However. On some papers and with sun light or critical light it can show. But you really look hard. Think it's more the type of paper it's stuck on but if on emulsion then paint to hide the glue
  3. Astramax
    Astramax Well-Known Member
    Think the op is asking about Vinyl flooring adhesive Wayner's! :confused:
  4. glob@l
    glob@l Member
    Yeh,vinyl flooring, should have been clearer!
  5. Wayners
    Really..oh.. Never mind
  6. glob@l
    glob@l Member
    I believe the fitters use a spray-on adhesive so if that is the case, does it leave a mess and would it be difficult to put right when it's had it's day? The guy from the measuring service asked if there will be a dining table in the room, since there will, he suggested fully fixing the vinyl?
