vokera linea 28 kw fault
Discussion in 'Plumbers' Talk' started by duff777, May 2, 2010.
  1. duff777
    duff777 New Member
    i am gas safe reg. but mainly on installs and fits had a problem with this boiler ,intermittent hot water ,turn your back and not working ,think ive traced to plastic motor head on divertor ,occasionally hear it whirring away are they quite prone to sticking at all ,heating working brilliant ,thanks duff
  2. Dick Puller
    Dick Puller New Member
    Sounds like it may be the actuator as you describe. Fairly common problem with them and a replacement is readily available.
  3. Tony Soprano
    Tony Soprano New Member
    Its also worth checking the heat exchanger,maybe slightly blocked ,as well as any NTC's
