VW T5 Speaker wiring
Discussion in 'Car and Van Talk' started by Jimfandango, May 5, 2021.
  1. Jimfandango
    Jimfandango New Member
    Hi all.
    I'm in the early stages of upgrading the old speakers in my T5, door and tweeters.
    My current plan is to put in some Focal 165 AS component speakers rather than the more expensive 'plug and play' types.
    My question is this. I need to pick up the initial output from the stereo to input into the new crossovers. Can I pick this up from where the cable plugs into the old door speakers or is it somewhere less accessible?
    Any other suggestions on which direction to take are welcome
    Cheers
  2. BiancoTheGiraffe
    BiancoTheGiraffe Screwfix Select
    That should be fine, I doubt there is anything between the existing speaker and the head unit
  3. tinkerbell60
    tinkerbell60 Member
