Wall cavity question?
Discussion in 'Builders' Talk' started by Berts, May 15, 2021.
  1. Berts
    Berts New Member
    I have an area where rain water has pooled against an external wall of a 1900s terrace. The bricks are now damp. There are no air bricks. The ground outside is raised concrete. I am thinking of bringing down the outside level and installing a aco drain. I will install some air bricks and clear out the cavity in the bottom few rows. There is cavity wall insulation in the wall. If I clear out the cavity as much as I can how do I stop the remaining insulation dropping to the bottom. I have been told gutter brushes can be pushed into the cavity. Can this be done? Does this make sense? I can't afford to have all of the insulation removed completely
  2. CGN
    CGN Screwfix Select
    Doubt there is a cavity given age of property.
  3. Berts
    Berts New Member
    There is definitely a cavity
  4. Abrickie
    Abrickie Screwfix Select
    Series of holes in bed joints and lock the insulation in place with expanding foam ;)
  5. Severntrent
    Severntrent Screwfix Select
    That builder was way ahead of his time
  6. Abrickie
    Not really, by the 1920’s cavity was more widely used than solid but it was definitely used in the 1890’s:)
    CGN and Severntrent like this.
  7. stuart44
    stuart44 Screwfix Select
  8. Mr Rusty
    Mr Rusty Screwfix Select
    Our 1902 house has cavity walls
