Hi Our garden has a brick wall as part of a raised decking framework. We've recently discovered water pooling on the concrete floor in front of it, which seems to be slowly flowing from where the wall meets the concrete. There are a few (what seem to be) drainage tubes above the first brick layer. I know these have had water dripping through them before, but not recently. These seem to be blocked with something hard, but nothing I've poked in has shifted it. Without ripping everything out, I can't see what's behind the wall. My best guess is that because these tubes are blocked, water is collecting at the base of the wall, soaking into the bricks, and flowing out the other side. Can anyone confirm my assumptions, or offer any remedy advice? Thanks!
By no means an expect on this, but your assumptions sounds reasonable to me. I have had to clear similar drain holes before, I used a 450mm long 8mm sds drill bored right through the pipe, it did clear them.
