Wall-fixings: Timber-framed house.
Discussion in 'Screwfix' started by Gummo, Apr 13, 2019.
  1. Gummo
    Gummo Member
    My son has just moved into his newly-built house. I'll be hanging pictures, mirrors, bathroom cabinets etc. soon.
    Do all timber-framed houses take specific fixings - do I use just cavity-wall types?
  2. Jord86
    Jord86 Well-Known Member
    Go along knocking the wall with your knuckle until you hear a dull thud, should be the counter battens nailed over the studs. They will be at either 400 or 600mm centres. For lightweight items just use redidriver plasterboard fixings or Spring toggles.
  3. Gummo
    Gummo Member
    So it's wooden studs just like cavity-walls?
  4. Jord86
    Structural studs (usually 89x38mm), 38x25mm battens nailed over the top, then plasterboard fixed on top of that is a standard construction detail throughout the country.
    Gummo likes this.
  5. Gummo
    Gummo Member
    Thanks comrade.
  6. bk2019
    bk2019 New Member
    hi, I have gone through your concern. i know a website where you can find solution to your problems. I suggest you to plz have a visit to the site.
    Plz click: timber acoustic panels
  7. goldenboy
    goldenboy Well-Known Member
    Do not click on this. Repeat do not click on this. All you get is an image of a tin of pork luncheon meat.
    Gummo and chippie244 like this.
  8. Gummo
    Gummo Member
