Wall lights
Discussion in 'Electricians' Talk' started by Diy Darren, Jan 29, 2004.
  1. Diy Darren
    Diy Darren New Member
    I am soon to be installing some new wall lights in my lounge - what type of back box do i need to put in the wall at the point where the wall light is to be positioned?
  2. im a martian
    im a martian New Member
    I don't think you need any. I just ran a wire from the fused switch i installed just above the skirting board.
  3. supersparky
    supersparky New Member
    some will need a besa box, although a normal 1 gang box will also do if needed.
    ss
  4. MICC
    MICC Member
    Besa boxes are a good idea but check with light fitting, as the screws do not always line up with the fitting.
  5. im a martian
    c'mon... and i might be over stepping the mark here - but you don't need any box - as long as the light fits securely to the wall, and you have a means of isolating to power to the light i.e. fused switch...
    best bet as always is to read the instructions you get with the light..
  6. MICC
    MICC Member
    A box is always better, if you chase down to the light position, you will have to dig out a hole in the wall to accommodate the connections, this could damage the wall decorations and make it harder to get fixings on the fitting.
  7. im a martian
    MICC i see what you're getting at now - but my wall light was fitted to a plasterboard wall (cavity) from a fused switch at skirthing board level. So the connections sat behind, in the cavity, and the light was anchored with cavity fixings.
  8. gerrin2owd
    gerrin2owd New Member
    You can manage without a box and there isn't any requirement for a switched spur, but an architrave box is neat and accomodates the connections to the fitting although you will still have to sort the fixings of the fitting to the wall.
  9. supersparky
    so your connections are hanging loose in the cavity
    ss
  10. im a martian
    ss, yep, they are...
  11. im a martian
    ... is that bad !!!???
  12. MICC
    MICC Member
    Sorry gerri, a lttle lost with your post here, can you explain?
  13. ban-all-sheds
    ban-all-sheds New Member
    The bottom half of a 35mm film canister makes a nice little box big enough to take a strip of choc-block, and small enough that most wall lights will cover it over completely.
