I have walls that have emulsion on them (likely eggshell or similar) water beads and runs off the surface. Im tanking the walls prior to tiling. I contacted Everbuild to ask about wall prep for the tanking membrane as the tub only mentions porous and semi-porous surfaces - they said I need to remove the pain from the walls to ensure proper tanking adhesion.
I was just thinking of giving it a sand with some coarse sandpaper to key the surface - has anyone applied this stuff on painted walls (walls as in skimmed painted plasterboard)?
I know the best way is to remove and use tile backer boards but for space reasons I cant add these over and the fact these are paramount walls I wanted to leave what are sound walls intact.
Hopefully someone has ahad a similar situation and can advise if I really need to remove all the paint back to bare plaster.
