Wall ties
Discussion in 'Builders' Talk' started by Allan 0789, Feb 13, 2018.
  1. Allan 0789
    Allan 0789 Member
    My ex has a flat up north the flats consisting of 18 in total 6 FLATS ground floor, 6flats second floor, 6 flats 3rd floor. We have just had new over windows fitted to all flats as they were rotted.
    There has also been 455 wall ties installed at £8.50each. You can see the odd cement were supposenly the builder drilled however on the 1st and 2nd floor there are NO wall markings (looked through zoom lense)
    My question is how do i tackle the builder and can I hire a detector, as they say there are hardly any original ties hence the works they done
  2. Bob Rathbone
    You should have checked as the work progressed, but it's too late for that now. You would need a surveyor to check if the ties were fitted, his report would be considered acceptable in any Court claim against the builder if it was required.
    blarblarblarblar likes this.
