Wall Vent Advice
Discussion in 'Getting Started FAQ' started by Nathan92, Jan 25, 2023.
  1. Nathan92
    Nathan92 New Member
    Hi,
    I have an internally fitted wall vent on a wall where I'd like to install a vertical radiator - see attached photos. Ideally, I'd like to cover the vent with the radiator but the existing vent sticks out quite a bit.
    I've tried to remove the vent but it feels pretty stuck. I live in a flat so can't access the vent from outside.
    What I'd like to know:
    1. How do I remove the vent?
    2. Should I replace it with a flat cover that will sit more flush with the wall? Will this be okay with a radiator in front?
    3. or should I block up the hole?
    I'd appreciate any advice!
