Washing machine noise?
Discussion in 'Engineers' Talk' started by Prady Gadaria, Dec 8, 2018.
  1. Prady Gadaria
    Prady Gadaria New Member
    Hi,
    i was wondering if there was anyone with any experience with washing machines, who could help?
    I have a panasonic NA127-V3B washing machine.
    Recently it has started making a really really loud noise on the spin cycle, similar to as if it was unbalanced, but all the time.
    There is also sometimes a sound as if the drum is rubbing against something. This sound also happens if I just move an empty drum around by hand too, but I cant feel any resistance, and its not all the way around?
    Also in the last couple of days, on a high speed cycle 1200rpm, there has been some sort of burning smell, but not so much like rubber?
    Does anyone have an idea what may be happening? The spin cycle still works, there is just a lot of noise (too much to run the machine overnight of even have a conversation in the kitchen whilst its running.
    Any help appreciated
    Thanks
  2. dobbie
    dobbie Well-Known Member
    Bearings worn out.
  3. Prady Gadaria
    Thanks Dobbie, do you know if it is easy to get someone to fix or just worth getting a new machine? this one is now over 4yrs old? Sorry I am completely clueless about home appliances.
  4. DIY womble
    DIY womble Well-Known Member
    I'd pop the lid off and watch it when the problems appear, diy disclaimer, I do rabbit ears occasionally ( and worse , not for customers )
  5. DIY womble
    It may wobble more than usual so be aware
  6. Prady Gadaria
    Thanks for the advice, but I wouldnt have clue what was normal, and what was wrong.
  7. Jitender
    Jitender Well-Known Member
    Does it have any manufactures warranty, only saying as I purchased one a few years and it came with 5 years warranty with the machine, the machine had to be registered within 30 days of purchase, unfortunately I never did :oops:
    The appliance developed a fault a a month back, the manufacture still repaired the item as they used the serial no. :)
  8. dobbie
    Just googled your machine number and there was numerous listings for bearing kits so it must be a common problem.
    The kits are only £7 odd so might be an idea to get a repair estimate if it is free.
    I do not repair appliances therefore cannot help on price.
  9. Astramax
    Astramax Well-Known Member
    Possible a drum stabilizer has sheared off.
  10. Prady Gadaria
    I've flipped the lid off, and looking at the machine when there is no noise, and excessive noise, nothing seems to be different, though it does sound even more like the drum may be rubbing against the plastic housing that it is in? Is this possible?
  11. Prady Gadaria
    I've managed to find the espares video on noisy drums, and it definitely sounds like that.
    I think I may ring around and find out how much it would cost.thanks for all your help guys
  12. DIY womble
    So with it switched off I would rotate the drum by hand and listen and feel to see if you could pinpoint further, diy disclaimer ....it's late and I've had a good night
  13. spirits are real 2016
    spirits are real 2016 Active Member
    i fixed someone's washing machine very noisy when spinning it was the stabilizing block on top of the drum the two nuts had come loose five minutes all fixed one very happy couple.
  14. ramseyman
    ramseyman Active Member
    It definitely sounds like the bearings have gone. To check that make sure the machine is switched off, preferably at the plug, open the door and put your hands either side of the drum and rock it. You will feel movement there if they're worn; however the tiniest amount is not uncommon. Replacing is easy enough if you're competent but needs the old bearings drifting out etc and takes a takes a fair while so depending on the age is probably not asn economic repair if you're payiny someone. The bearings also usually sit in an aluminium housing which can corrode and the repair sometimes doesn't last that long.
  15. KIAB
    KIAB Well-Known Member
    Possible something as got between drum & it's plastic casing, (outside of drum).
    ramseyman likes this.
