Washing machine plumbing
Discussion in 'Plumbers' Talk' started by furious_customer, Aug 10, 2018 at 12:16 PM.
  1. furious_customer
    furious_customer Active Member
    I had some new plumbing added to a cloakroom/utility room for the washing machine.
    I have about 18 inches of waste pipe coming out of the floor (connected straight onto a boss in the soil-pipe under the floor).
    What type of trap do I need before adding the washing machine spigot?
  2. rogerk101
    rogerk101 Active Member
  3. furious_customer
    So I have a vertical pipe coming out of the floor - how would I connect it to this?
  4. rogerk101
  5. just pumps
    just pumps Active Member
  6. furious_customer
    I was wondering if an S-trap would be best?
  7. RolandK
    RolandK Active Member
    Cut the pipe a bit closer to the floor and fit S Trap with an upstand pipe for the machine drain hose.
  8. The Teach
    The Teach Active Member
    Just source a S-trap with 40mm compression fittings on both connections but why make more work when purpose made wm/dw stand pipe kits are available and are known to work ;)
    using the correct fittings has advantages :)
  9. furious_customer
    I'm all for using the correct fitting, but I just don't know what that is!
    The stand-pipe kit has a horizontal connecition and I have a vertical pipe.
    Do I just add a 90 degree elbow to the pipe and then connect it to the stand-pipe?
    This will effectively form an s-trap anyway.
    Are s-traps bad? I keep seeing info on US websites suggesting that are the wrong thing to use.
  10. The Teach
    ;) Yes, it has been mentioned by others.
    are you in America ?
    furious_customer likes this.
  11. furious_customer
    Nope, but the laws of fluid-dyamics are the same in both countries. :)
    (Even after brexit I believe!)
  12. The Teach
    Ok, i consider i have been Trumped :p
    just pumps and furious_customer like this.
  13. furious_customer
    Seriosuly though, the suggestion seems to be that they can allow the trap to be siphoned empty?
    Not sure why.
    if I fit the standpipe, can I attach a washing machine spigot at the top (like the one under my sink)?
    Or would this cause a venting problem?
  14. just pumps
    Leave the pipe open.
  15. RolandK
    Illegal in parts of the US for some reason.
  16. furious_customer
    Does the machine not pump out water faster than the drain can remove it?
  17. just pumps
    Only if the vertical is too low, the pipe to the drain hasn`t the correct "Fall" on it or has a restriction in it.
  18. Alwaysworking
    Alwaysworking New Member
    F,F,S
  19. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    And the washing machine drain hose should enter the stand-pipe at the height of the washing machine.
  20. Heat
    Heat Active Member
    It also should only go into the standpipe a short distance of I would say approx 6” (150mm)
    To push it in too far can cause a syphon effect on machine.
    Best way to achieve keeping the hose correct distance is to use the U shaped plastic former that the waste hose snaps into
