Hi I'm in the process of installing a 'Water Filter' as I have Diabetes and need to keep hydrated throughout the day. The cost of bottled water is getting too much and a water filter is a more economical choice. The water filter I bought doesn't need any plumbing skills as the connection end punctures the water pipe as you screw it on the mains pipe. I'm still scepticle that this will work so I decided to put a washing machine tee valve on the main pipe instead. One with an on/off knob so if the water filter goes **** up or it doesn't and I need to replace the filter at any time I don't have to rush to the basement and turn the water off, I can do it there and then. My question was 'Why do 'T' valves never come with a nut on the 'T' section. The other two connectors have nuts and copper olive rings but that off shute never has a nut on it. Perhaps some one could tell me why. Thanks a lot.
It's for attaching hose from washing machine,dishwasher. https://www.screwfix.com/p/washing-machine-hose-blue-1-5m-x/43260
You need one of these.... https://www.bes.co.uk/15-mm-tee-wit...MIwuyp4ojZ5QIVDbTtCh1SbAYXEAQYBCABEgK9UPD_BwE
