Washing Machine Waste Connection
Discussion in 'Plumbers' Talk' started by SamRadders, Sep 24, 2021.
  1. SamRadders
    SamRadders New Member
    Hi all
    Just moved into a rental and the landlord has designed space for a washing machine next to a sink. Looks like the waste pipe should connect into the u-bend. Any suggestions what connections are needed as doesn't look like it will be flush enough just popping the grey pipe on top?
    https://ibb.co/HH1vkL9
    Any advice appreciated. Thanks in advance all.
    Sam
  2. just pumps
    just pumps Screwfix Select
    A Make sure that spigot is open and not blocked off (a pencil pushed in will tell you)
    B Use a small narrow band Jubilee clip to tighten the hose to the spigot (around 25-32mm jubilee clip)
    C Keep an eye on it when the m/c empties for the first time.
  3. andy48
    andy48 Screwfix Select
    And make sure the flexible waste pipe from the machine is taken up to just under the work top level then falls towards that spigot. Otherwise you'll get stagnant water sitting in the pipe.
    pppmacca43 likes this.
  4. pppmacca43
    pppmacca43 Super Member
    Looks like quite a small spigot to get a jubilee on, probably be fine but tbh if it was me I’d change that trap and put a mcalpine washing machine trap in. Might not be an option for u as it’s a rented accomadation. Would probably mean a minor alteration of the pipe, like a new elbow fitted.
    Are u in the UK, the tap fittings and the trap don’t look like common ones we use here.
    https://www.screwfix.com/p/mcalpine-appliance-trap-white-40mm/81714
