Washing Mc Samsung Ecobubble 8 kg & 9 years old is vibrating like hell.
Keshav
New Member
Machine is working but recently the machine was moved a bit ( 5-10 cm) from old position. With spirit level is seems ok within 1 mm. The back feet have been screwed in fully and the front feet used to level. Tried with a rubber mat from screwfix underneath. Machine still moves & the feet have sunk into the rubber completely. floor is wood. Any help from this community is much appreciated.
As above - if it was happy in its position before and these vibration have started recently and gradually. These Korean ( Samsung and LG) machines do seem to have premature bearing wear but this one has already served 9years . Open door, grab the drum and pull up and down to see if there is any movement. Also spin drum very slowly and see if you can hear any grinding noise.
Back
Top
