Wasps nest
Discussion in 'Just Talk' started by Sparkielev, Jul 3, 2020.
  1. METRO MARK
    METRO MARK Active Member
    Ya should have mixed up some little old home-brew Napalm, would have nuked then god dammm yellow jacket jam carrying little critters......For good
  2. Sparkielev
    Sparkielev Screwfix Select
    I'll tell the other half because it was her that went into the loft to do the mission :)
    Astramax likes this.
  3. sparky steve
    sparky steve Screwfix Select
    Went to my local store, picked up a can of fly spray and asked the assistant, is this good for wasps? The assistant replied,” No it kills them”.
    masterdiy likes this.
  4. jameswills
    jameswills Member
    I always use that home defense spray after removing any nests or webs to prevent it from happening again. Might be worth using in this spot now that the nest is gone.
  5. sparky steve
    METRO MARK likes this.
  6. Harry Stottle
    Harry Stottle Screwfix Select
    I went to our local chemist and asked for something for headaches, they gave me some aspirins and they worked a treat, only an hour later I'd got one.
  7. Astramax
    Astramax Super Member
    Good man, there is no point in putting yourself in harms way.;)
    Sparkielev likes this.
  8. Astramax
    More Columbo these days.:rolleyes:
  9. Bob Rathbone
    Bob Rathbone Screwfix Select
    I asked the chemist for something for a headache, he gave me a drum. :)
  10. Harry Stottle
    You must use the same chemist as me Bob.
    A bod walked in and said "I need some glasses" The assistant said "You certainly do, Specsavers is next door".
  11. dinkydo
    dinkydo Screwfix Select
    SPECSAVERS ! I was Just reflecting on life guys, as I get older all I need in life is a Specsavers a Boots and a Greggs...... yes life is all Specs Drugs and Sausage Rolls
    WH55 and WillyEckerslike like this.
  12. Hi, can anyone advise me on who to contact to have a wasp nest removed between the gutter and the roof tiles? I'm not sure if this is a council thing or do I contact a private company. Any advice would be appreciated
  13. Mark DM
    Mark DM Screwfix Select
    Private Pest control company. Think the council stopped offering this service years ago
  14. RegB
    RegB Active Member
    It will be empty at the moment, and won't be re-used.
  15. FlyByNight
    FlyByNight Screwfix Select
    @michaelwilliams
    Recently pulled out three from an attic with one being a ball about 450-500mm diameter - nothing in them at all. If you can get to it, do it yourself.
  16. BuildingMad
    BuildingMad Screwfix Select
    if you clear it & don't block up the access they will return & rebuild.
    Found one in the loft a few years back & removed it over winter, but did not know where the access was. Last year it was back in the same place, so I killed it after noting where they were getting in & blocked the entry hole. Don't think I will remove though.
    This one, many years ago, under a suspended floor: they were going through an air brick, which now has mesh over it, as do the rest. Killed it & removed it.
  17. RegB
    RegB Active Member
    I am unsure how Mr Williams is going to be able to do that, since the nest is "between the gutter and the roof tiles"! :)
  18. BuildingMad
    Good point. Did not appreciate the location mentioned.
  19. WildCat
    WildCat Well-Known Member
    Who owns the property?
