Waste Pipe Cutter
Discussion in 'Plumbers' Talk' started by Jez Brown, Feb 11, 2020.
  1. Jez Brown
    Jez Brown Member
    After a life time using a hacksaw, stanley knife and file, I have just moved into the 21st century and bought a rothenberger waste pipe cutter/plasticut kit. Wow what a flippin revelation, clip on turn, whoosh done, quick spray with soapy water for pushfit and jobs a goodun.
    The Teach likes this.
  2. KIAB
    KIAB Well-Known Member
    Try solvent waste fittings,you'll find they are a revelation compared to push fit.
    Hans_25 likes this.
  3. Hans_25
    Hans_25 Well-Known Member
    Always solvent waste here. And use muPVC for condensate drain.
  4. dcox
    dcox Active Member
    What’s muPVC? Different to what I’d call overflow pipe?
  5. Hans_25
    muPVC is a type of plastic - heat resistant.
  6. The Teach
    The Teach Well-Known Member
    There decent waste pipe cutters,handy in awkward pipe locations :)
    Roth also do a 110 plastic pipe cut & chamfering tool,only seen them used by import workers thou.
  7. Jez Brown
    Jez Brown Member
    I always use solvent weld, except when I am making a mod to existing pushfit wastes which was its first job, it was a joy to use. Haven't tried it on solv yet
  8. Heat
    Heat Well-Known Member
    Make sure you chamfer the end of cut pipe so that the O ring in the push fitting doesn’t get pushed out of position or damaged.
    Push fit waste pipe is good for many jobs if installed correctly.
    Must confess I have most tools and many I don’t really need, but I never have bought or used plastic pipe cutters. I just use a Roth pipe slice shear.
    Maybe time I bought a plastic pipe slice kit next time Screwfix has a deal
  9. Gazowl1975
    Gazowl1975 Member
    Who stocks the 110 soil pipe slice mate never seen one?
  10. Gazowl1975
    Gazowl1975 Member
    I've got em they are aa bit tight on abs though but do it very handy items. So ddo the do a 110mm slice did someone say? Have to use a vice though or two pairs of hands seem a bit uneccesary to me
  11. Jez Brown
    Jez Brown Member
    Bloody brilliant, get one you'll have a revelation
    Heat likes this.
  12. Gazowl1975
    Gazowl1975 Member
    Who sells them?
  13. Jez Brown
    Jez Brown Member
    Hi Gaz, got mine from screwfix, they aint cheap, but so quick and clean
  14. Gazowl1975
    Gazowl1975 Member
    110mm pipe slice from screwfix?
  15. Jez Brown
    Jez Brown Member
    [​IMG]Rothenberger plasticut 32mm, 40mm,15mm,22mm
  16. Jitender
    Jitender Well-Known Member
    Seen these but not used them.
    I have a pair of these and find they are brilliant. This covers all the sizes, as dont see a 25mm size in the kit.
    [​IMG]
  17. DIYDave.
    DIYDave. Well-Known Member
    Will these cut waste pipe then ? Say 32 and 40mm ?
    Seen them, thought were for cutting poly pipe stuff ?
  18. Jitender
    Yes they will cut it.
    I use them quite often and although expensive they are worth it.
    40mm solvent weld pipe just fits in but it will cut it.
  19. Jitender
    Nice clean and square cuts.
    Heat likes this.
  20. Heat
    I use similar older Roth version of the above pipe shear.
    You squeeze the handle to tighten blades against the 40mm or 32mm waste pipes and then move the cutter around the pipe initially as you cut into pipe.
    Works well
