Water Damage to Ceiling
Discussion in 'Painters' Talk' started by Glad its Friday, Mar 3, 2009.
  1. Glad its Friday
    Glad its Friday Active Member
    Hi Guys,
    I'm a plumber and have got a customer with a small amount of water damage to a ceiling from bathroom above. Typical yellow mark. Ceiling is lath and plaster but is ok.
    What is the best way to over paint this, or is this not
    possible? Do I need to get a pro in - don't mind doing a bit of painting as part of the repair but if it turns out to be lots of painting I'll get someone in. Area is about 2m x 4m.
    Thanks.
  2. potty painter
    potty painter New Member
    What is on the ceiling now?
  3. Glad its Friday
    Emulsion.
    Tks
  4. potty painter
    Just apply a coat of oil based primer/undercoat to the stained area, and emulsion the entire ceiling.
    Potty.
  5. Glad its Friday
    Cheers m8, nice one.
    I've got a builder who is a bit light this week so that'll do him nicely.
    Many thanks.
  6. apl
    apl Member
    Potty is spot on. Once the undercoat is dry, i paint that area first with a roller, then leave to dry, and then paint the whole ceiling. That way the undercoat gets at least two coats of emulsion.
