Water overflows when using pressure washer
Discussion in 'Plumbers' Talk' started by risenshine, Jul 24, 2020.
  1. risenshine
    risenshine New Member
    Hello all,
    First time poster, so thank you in advance for your patience!
    As the title states, when I use the pressure washer (and at times just the hose) I get a lot of water from the overflow going into the neighbouring garden.
    The hose is connected to the kitchen tap which is a mixer tap which is run through the house to the garden, in an ideal world I would have an outside tap, but the kitchen is at the front of the house.
    What solutions can be recommend before I go and hire someone in to fix this, one option I have seen is to have a non return valve fitted to the hot water tap, would this be correct?
    Many thanks
    RS
  2. jonathanc
    jonathanc Screwfix Select
    Sounds like you have mains pressure cold and gravity fed hot?
    do you have an isolator valves on the kitchen tap? If so just close the hot one when using the pressure washer. If not then non return valve or fit isolators or fit outside tap
    risenshine likes this.
  3. risenshine
    Hi Jon,
    I would need to check, but I will give you suggestion a go and see if there is a difference, the hot water taps definitely have a lower pressure than the cold. Fitting an outside tap would mean dragging the hose round even further and leaving the front door open, unfortunately not very practical or safe, wandering people and animals is an issue:)
  4. FlyByNight
    FlyByNight Screwfix Select
    Not the neatest solution, but can you get under the sink?
    If you can, then maybe fit a hose outlet to the cold feed and connect directly there.
    nigel willson likes this.
  5. nigel willson
    nigel willson Screwfix Select
    Deffo back feeding on the hot. Against water byelaws and you risk contamination of yours and others on that water network. As above put tap under the sink
  6. risenshine
    Hi Mike,
    yes I can, that is also a possibility, I do have a small downstairs toilet, would have to make some modifications but maybe more practical to fit a hose outlet there... or is it best from the kitchen sink?
  7. nigel willson
    Anywhere if there’s cold mains
  8. risenshine
    Thanks Nigel, Learn something new everyday!
  9. FlyByNight
    As said - anywhere there is a mains feed is preferred. What is the water pressure like in the downstairs toilet? DO you know if it is mains or stored? You can use stored - although the flow rate will be a lot lower
  10. risenshine
  11. FlyByNight
    It is not how te WC flushes but how fast it refills the cistern. They can be from mains or stored.
    The diagam will help you understand but you need to find out how your house is plumbed. That, for example shows just teh kitchen sink on mains water, and nothing else on te ground floor, however if you have a cloakroom, it is possible that the plumbing there will be direct.
    Do you know where you main stop tap is? If so, turn it OFF, run te kitchen cold and there should be no water flow. Then flush the downstairs WC, does it refill? If yes, it is stored water, if not, mains. Similarly with the local basin, does the cold still run?
  12. risenshine
    Thanks Mike, checked and it is a mains system, so will look at getting someone into fit a garden tap to the toilet basin
    Thanks all for your help.
  13. FlyByNight
    Have you though about DIY?
  14. risenshine
    Hi Mike,
    Though I have replaced taps, I would be wary of cutting pipes! I'd did look at a couple of videos and not ashamed to admit its beyond my skill set :)
  15. nigel willson
    Just remember, it’s easy when you know how. But then we know what possible problems there might be and what to do if they doo happen.
  16. FlyByNight
    At least you now have a better knowledge and understanding that will allow you to question a potential tradesman.
  17. risenshine
    Yes thank you, it makes a difference being knowledgeable when asking for help!
