Hi, We have water pooling against the seal on the shallow ledge of a low profile tray. It is around all of the edges. The water doesn’t move or evaporate. Never had a low profile tray before so not sure if this is a common issue. Any ideas on best way to fix? Thanks
It looks pretty normal, and is unlikely to cause a problem if the silicone is in good condition. In any case, there's not really much you could do to add any extra slope.
Thanks, I dry it out immediately and then some more water does form, but I think this is just further run off from the tiles. Once I have dried this off it doesn’t appear again
Thanks for the advice. I don’t think there is any slope at all on the edges. Am surprised by this but I guess that is the way the modern ones are designed.
Judging by the way the water is beading, it looks like it's a new tray or had new silicone sealant applied? It's a bit like when you polish a car, the water will just sit on top in large globules. If that's the case, you should find after a while the water will dissipate and not be noticeable.
