16.59 is the new figure. Not sure how I find the gas rate or should it be 24? https://www.plumbworld.co.uk/docume...0-c35-boiler-installation-servicing-guide.pdf
hi checkout page 8 table 3 Nett CV kW 24.3 DHW Flow Rate l/min 9.9 at 35°C temp. rise..... (gpm) (2.2) if the gas rate is 16.5 kw, calculate the water flow rate to complete the information. 16 kw will not heat water to a rise of 35 degrees (say from 10 to 45) at 9.9 l/min as DHW Flow rate .................l/min at temp............. if possible, the the temp rise, hot temp less cold temp................. the phrase used is delta T Greek symbol, triangle. when the heating is off, turn on bath tap (full on) feel heating pipes at boiler, are they getting hot ? i do hope its not too confusing ?
OK I’m not too sure exactly what you are asking me to check. Bit overwhelmed I have turned of the central heating for about 45 mins, radiators cold. Then I put on the bath and let it run for perhaps 7 minutes. The pipes around the boiler didn’t get warm like when the central heating was on. One pipe go a touch warm, like just a little but not warm like it was when the central heating was on. Apologies I should have made note which pipes I felt, but from memory the pipes for the bath and central heating were different pipes. Is there anything else I need to do? ps boiler stopped working again on 24th. Thankfully boiler cover meant someone came out on 25th.
