Water Running Under Conservatory
Discussion in 'Builders' Talk' started by mcfc4heatons, Apr 27, 2019.
Tags:
  1. mcfc4heatons
    mcfc4heatons New Member
    Looking for some advise please, had decking removed at rear of house to reveal hole at bottom of conservatory wall. Water is running under the conservatory when it rains.
    The conservatory does have a manhole/grid underneath it which has access/capped. Should I be worried about water running down there under the conservatory, should I block the hole off, will the water readily find its way to the drains anyway or could it cause damage?
    [​IMG]
    [​IMG]
  2. gas monkey
    gas monkey Well-Known Member
    if you have had no probs before all thats changed is that you are a bit nervous do not fret
  3. ecoplumbing
    ecoplumbing Active Member
    I wouldn't rule out the possibility of a blocked drain, manhole shouldn't of been built over, seen this a lot with builders taking shortcuts. Just wondering if that's a concrete lintel on the pic and if the manhole is under there? I'd investigate it further just in case it is a blocked drain, dye testing may help if you've got a drain to put the dye down?
  4. KIAB
    KIAB Super Member
    Blocked drain,possible conservatory wall settlement cracking pipe.
    Agree with EP,it's always sloppy work building over a manhole,should be avaoided,can cause so many problems.
    stuart44 likes this.
